Company Logo Shop Now
TractorLinks.com
900 push rod gasket
Dhw
06-12-2019 18:00:11
I know this has been answered before but my push rod cover gasket came with a square cut in it. Does the square face up or down ? Why if there is a reason
Dan
RobCons
06-13-2019 04:41:15
 Re: 900 push rod gasket in reply to Dhw, 06-12-2019 18:00:11
I like Showcrops thinking. With the cut up it forms a pouch to catch oil.
showcrop
06-13-2019 04:33:52
I have always put it down so that the gasket is holding less oil.
WayneIA
06-12-2019 18:16:05
Probably to compensate for the indentation in the cover for the distributor, But what you should be watching for is the fact that the three mounting holes in the gasket are not in the center of the gasket, likewise the mounting holes in the cover are in a line but not on center either.
Dhw
06-12-2019 18:31:57
 Re: 900 push rod gasket in reply to WayneIA, 06-12-2019 18:16:05
Yep.....faces one way....but which way is it flipped?
WayneIA
06-12-2019 18:47:36
 Re: 900 push rod gasket in reply to Dhw, 06-12-2019 18:31:57
I would put the hole forward and if I am not mistaken once you line the holes in the gasket with the holes in the cover and the block the hole will be up. If it is put the opposite the gasket will not be a perfect fit to the cover.
Dhw
06-12-2019 19:07:46
 Re: 900 push rod gasket in reply to WayneIA, 06-12-2019 18:47:36
Thanks Wayne
I'll take another look when I'm not crazed in the morning. I thought the gasket fit good with the cut the way it is or flipped down. The way the picture is what I originally thought.....the old one I peeled out was solid with no cuts.
Maybe this is a catch-all they made up for a line of older Ford's. Just can't figure why the cut is in the gasket
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
