(quoted from post at 12:41:18 06/12/19) Unit Number 8F05B means it was assembled on June 5 1978 during the day shift. So the numbers are from the sticker under the hood? Then it's definitely a 3600 and not a 3910.
I m getting a quote of 1350 dollars for dent and rear harness(quoted from post at 14:15:31 06/12/19)
Everything about it looks to be a 3910 Series II, grille, lift controls, planetary rear axle.
3910 unit number should start with CA4, not 2.
8F05B could be a build date of June 05, 1988 which is correct for Series II models.
NH is the only place to get a wiring harness for that model, if it burnt the wiring at the cluster you'll need a complete harness.
Cost around $275.
Ironically I'm fixing to bring a neighbors 3910 to my shop with a burnt harness, it didn't burn as bad as yours.
Thanks for the advice that seems like a good idea(quoted from post at 16:16:31 06/13/19) Can't help you with your model, but that's a
common problem with Fords, positive wire shorts
out on the hood and they burn up, wrap a hose or
something around the positive wire so that dosent
happen again. Had that happen to a 4600 years
ago.
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto26222.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto26223.jpg">
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto26224.jpg">
