Ford 5900 diesel
afisher
New User
Have a bush hog bale spike on front of tractor,I unhooked the 4 ports from the loader and connected the 4 round baler hyd. Lines to the tractor ports all was good and I started baling hay. When I was done I unhooked the baler hyd lines from tractor and hooked back up the bush hog bale spike lines...problem. The loader wouldnt hardly move up/down nor tilt well now. You can see the hyd. Lines surge when you toggle the levers to get the loader to move... Help! Thanks in advance.
(quoted from post at 20:28:22 06/11/19)
sounds like one or more aren't plugged in good, or you have a couple of hoses swapped
What he said...
often the lines will pop part way out and not work, or you crossed a line. On some models, you have to turn "on" a flow lever as well after you plug in.
