Company Logo Shop Now
TractorLinks.com
Order Ford 4400 Parts Online
what type fluid I use for power steering for 4400 ?
marlin54
06-10-2019 21:20:54
I have a 1965 4400 backhoe with cannister type system..Its mounted above the pump in a cannister....cylinder is up in the bolster ..rebuild it with new seals..was wondering what different kinds of fluid can I use for this unit? thanks
sotxbill
06-12-2019 05:58:15
 Re: what type fluid I use for power steering for 4400 ? in reply to marlin54, 06-10-2019 21:20:54
He is asking about his power steering... please reread the post.
And... there is 54 years of proof that the original spec is just fine for the power steering, the transmission, the rear end, for wet brakes, for dry brakes, the blinker fluid reservoir, etc...etc.. etc..
Sean in PA
06-12-2019 04:42:36
Which sumps? Rear axle/hydraulic sump on a 3 cylinder 4000 has both wet brakes and a wet clutch pack for the PTO.
sotxbill
06-11-2019 19:50:03
You really dont need 134D for power steering in a 4400.
And almost any power steering fluid you can buy,, Automatic Transmission fluid, or tractor rated hydraulic fluid will work fine. There are NO wet brakes, or wet clutches, and there is 54 years of proof that the regular fluid worked just fine.
Did I say they have been using the regular fluids for 54 years with no failures attributed to this fluid in the 4000 series tractors.
Leave the synthetic blinker fluid to the neysayers.
Shetland Sheepdog
06-11-2019 05:52:38
The original spec was M2C41 or M2C41A.
Has been superceded with 134D
Check Break
06-10-2019 21:49:47
FNH M2C-134A/D or one that "exceeds" this spec.
marlin54
06-11-2019 04:08:23
 Re: what type fluid I use for power steering for 4400 ? in reply to Check Break, 06-10-2019 21:49:47
I dont think they had that in 1965...so what did they use then?..I think Im going with regular hydraulic fluid..wont be using it in winter ......its old and would probably leak with anything thinner ...I will see what happens...thanks
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
