Company Logo Shop Now
Ford 7610 (BB70846) Leaks Hydraulic Fluid from brake rods
cranecentral
06-10-2019 13:57:36
Had such great luck with my other issue i thought i would try my luck again!!
1987 Ford 7910 leaks Hydraulic fluid from the rear Brake rods when @ the full mark. Replaced the Dust Seals obviously no change. Dealer says nothing else i can do. Any Thoughts?
cranecentral
06-12-2019 04:20:23
 Re: Ford 7610 (BB70846) Leaks Hydraulic Fluid from brake rod in reply to cranecentral, 06-10-2019 13:57:36
Thanks for the INFO!!
Sad fact about the local dealer.
sotxbill
06-11-2019 19:55:06
unless the rods are scratched up or the axle housings are damaged, or... someone put the seals on incorrectly????
I have had one seal with a pin hole in it, otherwise all of them have sealed perfect. Some are a bit more tasky, but they all installed ok except the one with a pin hole in it. It was in an open package so now I know why.
Bern
06-10-2019 14:08:07
 Re: Ford 7610 (BB70846) Leaks Hydraulic Fluid from brake rods in reply to cranecentral, 06-10-2019 13:57:36
Dust seals? #19 is what you need to replace. Fairly easy to do.
Also, find a new dealer.
Latest Ad: Looking for two coulters and mounting brackets for a JI Case centennial plow [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
