Hogfarmer10
New User
We have a 7700. Mowing hay and when we?d
switch from low to high in dual power, pto would
stop and tractor would hesitate for just a split
second. Finally, the pto completely stopped.
Checked hydraulic pump pressure ( I tee?d into the
dual power line) and it was running between 50-80.
Asked dealer. He said should be around 200.
Replaced pump. Still no pto. I never lost 3 pt hitch
or remotes, and the tractor drives ok, so that should
mean not the input shaft. Also, the new pump was
pumping 220 psi for 10 minutes and still no pto. Any
help is truly appreciated.
