murray moore
Installed selector to transmission cover and dash according to manual. Sos cable at 2 3/4?. Selector cable attached with selector on 10. Then mived lever to Park and installed.
Started tractor. Ran it for a few minutes. Heard strange whirring sound. Shut off tractor but starter motor wouldn't shut off. uGGH!
Frantic run to turn key off. Pulled key. Starter motor kept running but not engaged to flywheel. Starter getting hot. Pulled ground wire from button switch. Starter kept whirring away and now really hot. Finally disconnected positive lead from battery. Finally shut off starter motor.
What caused this to happen at this start attempt?
12V. Sudden new challenge. With key now pulled and ground wire at button switch pulled, i touch the lead to positive post and starter engages.
Seens like its grounding somewhere?
Is this a sudden solenoid issue? Or something ekse i cant see.
