I have a '63 Ford 2000 4 Cylinder. Bought it last year with 106 original hours on it and use it as my primary tool on my small farm; now up to 190 hours. Have not had any major maintenance problems up until now, keep it lubed and PMCS before and after each use.
Two days ago I was tilling one of my market garden plots and the PTO would not engage and the shift lever would not move. I tried to remove the side inspection plate but it was stuck and the shifter crank had popped out of the spacer in the shifter shaft. I was able to wiggle it out with some effort and after doing so the the shifter shaft moved freely by hand when the clutch pedal was depressed.
I decided to remove and inspect the PTO shaft and everything there looked good, nothing bent, no indication of shavings and the tines on what I think is called the shaft coupling looked okay even though I could only inspect it from the rear of the reservoir with a flashlight.
I reseated the inspection plate and the shifter crank/lever and confirmed that it engaged the shifter shaft correctly. I reseated the PTO shaft and when I start the tractor the PTO is engaged as soon as I release the clutch, even with the shift lever all the way forward.
I removed the PTO shaft and started the tractor with the PTO shaft removed. Inspecting it from the rear I can see that the tines in the coupling link do not turn with the PTO disengaged (the lever all the way forward) and that they do spin once the lever is shifted to the rear (the PTO engaged setting). This would indicate to me that this is normal operating behavior.
However once I put the PTO shaft back in the PTO shaft is again engaged as soon as I release the clutch. I repeated the whole process again to see if I had missed something and again everything appeared to work correctly (if my logic is right) with the PTO shaft removed.
I am not a mechanic, just a fellow with a shop manual trying to puzzle through this. Any help with what I might be missing?
