The gear shift lever (NDA 7210) and the Transmission Gear Shift Shaft (ND7212 A) have an enormous amount of
slop between them. The Trans. gear shift shaft actually has a shoulder worn into the bottom of the taper.
The key slot is also worn. I would like to replace the Trans. Gear Shift Shaft. Will it come up and out of
the transmission with the Transmission in tact in the tractor?
OR
Has anyone come up with a fix for this?
OR
