53 Ford NAA Transmission
moving78
New User
53 Ford NAA transmission locked up. Gear shifter doesn't move, but Sherman combo does. Starts up fine, and when engage the clutch, RPMs go down, but tractor doesn't move. First time this happened, towed it out of the field and tranny broke free. Second time, disengaged and reengaged Sherman combo several times, and finally got it moving. Any thoughts on the problem and solution? Thank you!
I would pull the top cover off the transmission and see why you can't move the gear shift. I would not pull it or force it to correct itself anymore. You could really damage something.
Pulled it and here s what I found. Not sure what I m looking at. Is that locking but supposed to be tightened down?
