Working on a 8970A. Issue is a F312 fwd solenoid
circuit fault. Found the fwd solenoid wires naked
and the insulation melted. Replaced the solenoid,
still have the same code. When I go into mode 7 to
energize to solenoid it does not magnetize. I can
unplug it and read battery voltage, with a load in the
circuit ( light bulb or solenoid) I don?t read any
voltage.
I?ve check the wiring all the way back to the
connector under the cab. Has anyone seen one of
those solenoids short and mess up the chassis
control module?
voltage.
control module?
