Ford 4000 Drawbar
nashranch
anybody out there have a ford 4000 drawbar and stabilizer arms For Sale??
Give me a Call if you do and maybe we can work something out
Mike @ Home 541-747-7499
Cell 541-228-5453
I don't have any of those parts for either 4000, but you should specify which one you have, the earlier 4 cylinder 4000 or the later 3 cylinder 4000. As far as I know, those parts are different between the two. Also, does yours already have the drawbar bracket and it just needs the drawbar, or do you need the bracket as well?
(quoted from post at 11:42:05 05/29/19) I don't have any of those parts for either 4000, but you should specify which one you have, the earlier 4 cylinder 4000 or the later 3 cylinder 4000. As far as I know, those parts are different between the two. Also, does yours already have the drawbar bracket and it just needs the drawbar, or do you need the bracket as well?
Mine is a 1969 3 cyl, diesel and I do have the bracket, just need the drawbar
If your tractor is a four cylinder, you also need to specify whether or not it's a row crop, as those parts are different between standard and row crop tractors.
Personally I like the straight drawbar C5NN805F-SPL over the offset ones.
With the offset bar in the lower position it's to low for some of my implements and in the raised position it's near impossible to hook up a CV joint style pto shaft.
(quoted from post at 07:24:02 05/30/19)
Good info Destroker my bro works for steel company so I got him getting me a straight chunk o steel 34 5/8 long X 2" wide X 1 1/4" thick.
You can try it but probably going to bend, drawbars are tempered like spring steel.
I've had one cheapo bend but most will break when overstressed.
