Just did an in frame rebuild. Got it up and running. Starting perfectly firing right up running well. The water temp gauge on the tractor never worked so I installed a new aftermarket gauge. I found power on the two posts on the gauge cluster. The wires were cut by the previous owner. I spliced into one to get power and the water temp gauge worked. I button everything back up and started the tractor. I no longer had power to the water gauge or the two posts on the cluster. Nor did the gas gauge work. I basically had no power to the cluster. The tractor also was running rich and it overheated. That never happened since the rebuild last week. And I ran it off and on since then. I have no idea what I did or if something failed. I did weld on the throttle to get it back together. I just have no idea what is going on here. I am not the best with electrical and I don't quite know what delivers power to the cluster and why that would cause any of theses problems..
please help!
In the lower picture is where I found power on the cluster. That was the only place
please help!
