fordtractors143
Ok so I bought a ford 2000. I believe it is a 63 Serial number 2130 0. 17003. I have been working to get each major system running again. Ive been successful so far with the loader, power steering, engine etc. Today however i wanted to get the rear hydros working. I started by draining the hydro reservoir. Then i refilled to full according to dip stick. I bled the hydraulic pump by cranking until fluid came out of plug on the pump. I put it back in and attempted to actuate the rear hydros. While doing so yellow milky fluid began coming out the shifter. SO it would seem this was a fast leak as the hydro reservoir appeared empty nearly instantly. Any help, tips would be so very appreciated.
