Yesterday I pull the cover off my '63 4000. It was clean looking inside the case, but the underside of it was gunky. I completely tore it down, except for the lift arms, and the cylinder assembly. I quit there to sit with my wife. She's been six for a few days, she comes first.
I don't now the correct way of tearing it down, but it's apart, and nothing got broke. lol I'll definitely read my service book on how to reassemble it. I mopped up the black oil that was left after draining it. I didn't feel any type of grit at all in it. I was surprised to see the inside painted red. To me everything look in great shape.
I notice that one of the O-rings that is on the case-cover seam, one didn't make it into the hole it suppose to be in. It was smashed. You can see what there was of it, in the picture of the cover.
One thing, I couldn't get the draft lever to engage before, and with it sitting on the bench, I could not get the lever to move. The lever is not frozen, it moves, it wouldn't engage. Nothing inside was stuck, it all moves freely.
The follower pin looked a lot better then I was expecting to see. It has some wear on it but not bad. it looked it the arm has been worn by the part I the follower rides on. (I have no idea what it's called ....yet!) I will some how press the pin out and rotate it, and press it back in. Some how, I have no press, just clamps, and a vice.
I took every thing apart without changing any adjustments. How will I set the adjustments, without a lift bar gage tool thingy.
Next thing I do is, clean everything. It's a black mess oily mess.
If you see something that needs attention, or something I need to do to it, please tell me.
Thanks, Pat
Thanks, Pat
