tysmobiletractor
I have a lift cover off - lift cylinder removed - but can't see how to remove the unloading valve on this tractor.
When I tested the 3pt, it was leaking a good stream of oil right out of the Baffle plate [#38 in the FO-20 Manual]. I have removed the control valve and it appears to be fine.
I would like to remove the unloading valve but haven't got it to come out yet. .... ???? Any help on how to remove this unloading valve ?...
Any idea what could cause oil to leak out of the Baffle plate?
Manual shows there is an o-ring with the unloading valve.?.......... I would like to remove clean and replace this o-ring. Maybe I find a problem there?....
Anyone else has experience in this?
Thanks
Thanks
