Lower Linkage end assembly
Ian Connolly
New User
Does anyone know if the lower linkage end assemblies (Category 2) from a Ford 6600 are compatible with those for a Ford TW30. They have different part numbers(EONNC877AA for right hand on 6600) and (D8NNC877BA for right hand on TW30). Thanks in advance for any reply.
(quoted from post at 22:10:01 05/25/19) Does anyone know if the lower linkage end assemblies (Category 2) from a Ford 6600 are compatible with those for a Ford TW30. They have different part numbers(EONNC877AA for right hand on 6600) and (D8NNC877BA for right hand on TW30). Thanks in advance for any reply.
I can't imagine that they could be. There is a big difference in size and the pins would be different sizes.
It would appear than lower lift arms are sized for weight, but also for the biggest tire that would be installed on the machine... So the 6610 arms might be a couple of inches shorter and put a very wide implement closer to the rear tires. as well as be lighter.
Seems like I see this most on the 4000s where the wheel size was all over the place. Some have short arms and others have the longer arms and flex links on them.
Sorry not a definitive answer.
