960 hydraulic fluid
grandpa Love
I think the seal between
transmission and hydraulics is
leaking. Seems like the
transmission gets over full and
hydraulics get low. Will the fluid
only leak one way?? I figured it
would even out? Split it to fix ?
sounds like the classic rusted out hydraulic pressure tube - there was a thread here within the last month about replacing it - I'll see if I can find it -
That was quick! Thanks. Doesn't look like to bad a fix. Hydraulics are still working fine. Fluid is still showing on stick. Been slowly dropping for several months, transmission has slowly over filled.
