1954 Ford 860 Hydraulic diagram and help
gheath
Help I have an Ford 860 tractor that seem to have some problem with the hydraulic. When I first crank the tractor and try to lift a piece of equipment it lifts real slow. It will finally come up but the motor has to be running fast for it to work. After the equipment raises it has no problem staying raised after the tractor is turned off. Do this tractor have a filter on it? Does anyone have a diagram of the hydraulic . I am used to Massey and have no idea where to start. Any suggest? I have put a lot of time in on this problem. Thanks for any help
Since it will lift and hold up, I would be looking toward pump.
