position of flywheel to crankshaft for a 192/201 t
marlin54
Getting ready to bolt flywheel on crank for a 192 /201 motor and wondered if there is a certain position it has to be bolted on as I see they
flywheel has been balanced at factory . I have all timing gears lined up and believe its on tdc . ?
The bolt holes are spaced so it will only go on one way. If one or more holes don't line up, it's not on right.
