FordManiac
Previously I asked about value and thanks for your responses. So I m trying to decide if I should sell it for a later model. I have most items fixed now including a new steering sector. The steering is my biggest worry with this tractor as I understand the early hydraulic setup is not as robust as the newer hydrostatic systems in the 85 and later models. The new steering sector wasn t cheap either so wondering if this system is so weak that I will probably have more issues. I need the loader so I know the extra weight is the issue. This being said I m trying to decide on the following:
1. Keep what I have provided it s expected to hold up ok.
2. Keep Allied loader and use on newer Ford 5610-7610 etc
3. Go with newer New Holland or Massey Ferguson tractor.
Thoughts?
Thank you,
Thoughts?
Thank you,
