Jmcdonald70
New User
I recently acquired a Jubilee. The lift was working when I picked up the tractor but then would begin to not lift after about 30 minutes. I figured I would repair the lift cover and replace the safety pressure valve. I done all this and while I was in there noticed the back pressure valve stuck. I cleaned it up and seemed to work. I put it all back together and now nothing works. Lol. I have tried priming at the pump with no air present. I have fluid at the top casting hole with lift cover removed. I have tried blowing air through the dipstick. One thing i noticed is with the tractor running and acorn nut removed at the back pressure valve i can push in on it and the arms will raise only with no weight. There is also a seepage of oil coming out where the acorn nut is located. The one thing I did not do while in there (slap in the face) was replace the cam follower pin. Not sure how to do that. Please help me to figure this out. It is driving me crazy. Thanks in advance!!
