Hello all.
The 860 I bought a month or two ago is up and running. Needs some carb tweaking, but I m happy with it overall.
I completed required it, but am having issues with the charging circuit. It came with a three terminal Motorcraft alternator and your normal 3 post ford voltage regulator.
I m not familiar with the STATOR terminal at all on this alt; I understand generators and 10SI series alternators.
I d appreciate any help letting me know if this wiring diagram [i:a33ca66bcc]should[/i:a33ca66bcc] work. Yes, I left out the ignition circuit for simplicity.
I get only 12.7 volts at the battery running at 1250 rpm so it s not charging.
I m not opposed to ditching it in favor of a Delco, but hey...run what ya brung.
