Post a couple weeks ago. Still have problem. Tractor has been running all spring. Went to start and no go. Cranks good. Six volts. Checked spark and got blue spark that jumps 1/4 in. or more. No fuel on plugs. Good flow at carb. Removed carb numerous times. Cleaned thoroughly. Put in kit. Finally took carb to another NAA and swapped and the other one started right up with carb off one that won't start, which seems to say carb is not the problem. Gov. rod is hooked and moves freely. Tested compression, got 100-110 on all cylinders. Looked at static timing and it appears ok or at least close. Hasn't been changed anyhow. In fact nothing was changed since it started a week prior. Plug wires are correct. I'm looking at manifold, but can't see any cracks or anything wrong. No blockage at tail pipe. At wits end. Thinking there has to be a blockage in the manifold somewhere, but how would that happen just sitting? What else should I check? As ya'll know removing manifold not easy with the old rusted nuts, etc.
