James_1967
Hi,
After some advice, I am doing up an 8000 and the splines on the r.h. lower link mounting yoke and, to a much lesser extent, the shaft it sits on are pretty worn. It is not anticipated that the tractor will do much more three-point work, however it needs to be in a presentable condition.
I looked up the yoke on the parts system, its no longer serviced. So is it available from a non-OEM?....or does anyone have a suggestion on how to tighten it up on the splines?....I did contemplate drilling and tapping a thread in to force it tighter against the shaft.
