Company Logo Shop Now
TractorLinks.com
Order Ford 860 Parts Online
860 12v Wiring Diagram
JCinKY
05-15-2019 09:43:38
Hello all.
The 860 I bought a month or two ago is up and running. Needs some carb tweaking, but I m happy with it overall.
I completed required it, but am having issues with the charging circuit. It came with a three terminal Motorcraft alternator and your normal 3 post ford voltage regulator.
I m not familiar with the STATOR terminal at all on this alt; I understand generators and 10SI series alternators.
I d appreciate any help letting me know if this wiring diagram should work. Yes, I left out the ignition circuit for simplicity.
I get only 12.7 volts at the battery running at 1250 rpm so it s not charging.
I m not opposed to ditching it in favor of a Delco, but hey...run what ya brung.
JCinKY
05-15-2019 13:12:19
 Re: 860 12v Wiring Diagram in reply to JCinKY, 05-15-2019 09:43:38
Thanks. Now I know what it was used for.
I ll have the alt checked next week before I buy a regulator. They look to be about $15-$30. I ll through a cheapie at if the alt test good.
Can get a 10SI for $50 if the alt is bad.
JMOR
05-15-2019 12:51:21
Quoting Removed, click Modern View to seeNo use for alternator Stator connection here. In previous life it was for electric choke/tachometer/regulator turn on, etc.
JCinKY
05-15-2019 12:41:18
The master himself....
I saw that old post yesterday while on Google but couldn t see the pic.
So I need a ford automotive v-reg? Simple enough. This is what it had when I bought it but no clue if they actually got it to work.
And I don t use the Stator lug on the alt?
Thanks JMOR and Bob
JMOR
05-15-2019 12:03:39
Quoting Removed, click Modern View to seeLooks like you have an alternator wired to a generator voltage regulator. Thank Bob for this simplified diagram.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
