Company Logo Shop Now
TractorLinks.com
Order Ford 800 Parts Online
Ford 800 model 860
Diggerdon
05-14-2019 19:25:48
Replacing front axle support bushing. I have applied 12 tons to the bushing and it doesn't budge. Anyone have any idea how much heat I can apply to the center axle to see if this will break it loose. Or does anyone have a better idea on how they did theirs .
Off Road SHO
05-15-2019 04:01:30
 Re: Ford 800 model 860 in reply to Diggerdon, 05-14-2019 19:25:48
Apply enough to really heat up the old bushing red hot. You can't apply enough heat to warp or shrink the cast housing so heat that mother up with an oxy acet torch, when it cools down it will shrink.
Or drive a thin flat blade screwdriver in between the bushing and housing. Don't worry about scratching up the housing, your new bushing will cover it up.
Tom
Dr ken
05-15-2019 03:20:24
. How did your clutch shaft turn out no pic.?
Diggerdon
05-16-2019 21:20:57
 Re: Ford 800 model 860 in reply to Dr ken, 05-15-2019 03:20:24
Here are the pictures of my clutch pedal shaft. It's not very pretty , but the bushing fits tight and the pedal is snug. Trying to talk the boss into let me get a bigger chuck (3/4 or 5/8) for my drill press, or a small lathe so I can turn shafts and bushings. Seems to be a lot of these parts we can't buy new . I keep telling her it will be cheaper for me and others.
michford
05-15-2019 03:01:58
I personally have not done this, but I have heard of running a bead of weld inside of a cylinder liner to shrink it to remove. Might try this for the bushing.
Threewilsons
05-14-2019 19:48:31
I just changed mine along with the pin. I had no luck with pushing and got tired of chiseling and finally took the oxy acetylene torch and carefully cut it out. It was a piece of cake and I should have started with it. You d actually have to work at it to mess it up as heat doesn t transfer quickly to that big chunk of iron.
pinball
05-14-2019 19:35:04
if its just the bushing take a chisel and chisel down one side. just be careful not to get into the casing.
Diggerdon
05-14-2019 19:47:11
 Re: Ford 800 model 860 in reply to pinball, 05-14-2019 19:35:04
I'll try that next, bushing is awfully thin
Dean
05-15-2019 04:33:31
 Re: Ford 800 model 860 in reply to Diggerdon, 05-14-2019 19:47:11
Be advised that the bushing is hard.
Might want to grind a weak spot with a die grinder.
Dean
Diggerdon
05-15-2019 21:02:19
 Re: Ford 800 model 860 in reply to Dean, 05-15-2019 04:33:31
Got it out by grinding a grove along the seam in the bushing . Then using a small chisel in the grove . Your correct that is one hard puppy but very little damage to the center axle. Pictures to come for the clutch shaft
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
