Ford 8000 lower link splines
Hi,
After some advice, I am doing up an 8000 and the splines on the r.h. lower link mounting yoke and, to a much lesser extent, the shaft it sits on are pretty worn. It is not anticipated that the tractor will do much more three-point work, however it needs to be in a presentable condition.
I looked up the yoke on the parts system, its no longer serviced. So is it available from a non-OEM?....or does anyone have a suggestion on how to tighten it up on the splines?....I did contemplate drilling and tapping a thread in to force it tighter against the shaft.
Find one off of a later TW in a salvage yard. This updated design will allow you to clamp the arm onto the shaft.
(quoted from post at 10:56:42 05/12/19) Hi,
James, if you were to share your location someone here may be able to help you find a tractor that is being parted out.
I'm in Britain, aware that this is primarily an American forum.......the 8000 is a bit of a rarity for us so its tough
getting good info on our local forums
