axle support bushing for 860 ford tractor
ejensen
Woubld like to know where to get a threaded front bolster axle support bushing for a ford 860 tractor
There are a couple different bushings available for that tractor , but I don't think either one is threaded. The pins are though, is that what you referring to?
BigDanT
I meant the pin ,probably correct name that the front axle pivots on
The pro shaft for front hydraulic pump for loader goes to brought this pin that I called a bushing. Tried to weld it in place couple years ago looks Ike threads back of the pin. Threads gone in the bolster so no way to secure it. Was planning to try welding again No new or used bolsters That I could find. Your thoughts on my welding the pin in place would be appreciated
Chris
I had a similar issue with a 641 with heavy duty axel. You can tell if yours is the HD when the pin has a hex head end on it. Threads in bolster were shot so I ran a large bolt through the pin and nutted it to back side of bolster. Pins and the HD bushing were hard to find and very expensive so I made my own with a lathe. Unfortunately if you?re running a FEL on the tractor you can?t do that. At that point I would have no issues with welding the pin in place. Other than a different bolster that may be the best option.
BigDanT,
Outstanding pictures,information, Thank you. Chris
Have included a picture from the manual for the 860. Friends I am helping bought the 860 in 1995 . From the picture are you able to tell what type of front end? pin is threaded.
Chris
If it looks like the manual it is a standard front end with threaded pin. New Holland parts site has two numbers listed for the pin, (see link) you will have to measure yours before ordering. This site may have them but if not they?re available elsewhere.
Ok
