Company Logo Shop Now
Order Ford 640 Parts Online
640 distributor timing
5 Forward
05-11-2019 07:52:52
What is the correct initial timing for the 640 gas engine. The owners manual says 8 degrees. the shop manual says 4 degrees at 450 rpm. Is it set at 8 degrees engine off, and engine running at idle it advances to the 4 degrees at 450 rpm.
Dean
05-11-2019 13:54:32
 Re: 640 distributor timing in reply to 5 Forward, 05-11-2019 07:52:52
4 degrees BTDC at 450 RPM or below.
Dean
JDEM
05-11-2019 10:27:56
As the other guy stated, more advance at the RPM goes up, not the other way around. 134 gas engine is supposed to be at 30 degrees advance with the engine revved up.
Bern
05-11-2019 09:35:38
When timing advances, the number should get higher, not lower. So if you start at 8, it should go to 10, 12, 14, etc. as you rev it up.
5 Forward
05-11-2019 11:32:08
 Re: 640 distributor timing in reply to Bern, 05-11-2019 09:35:38
Yes that makes sense.
Latest Ad: need 3 point arms (with the ball) especially need the [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
