Company Logo Shop Now
Order Ford 5000 Parts Online
5000 rear split
Fordfarmer
05-10-2019 16:46:30
New PTO input shaft came today, should have time to put it in tomorrow. Since I've never done a rear split before, should I put the gasket in dry, or with a little non-hardening Permatex?
RickB
05-11-2019 02:36:18
 Re: 5000 rear split in reply to Fordfarmer, 05-10-2019 16:46:30
I like the aerosol Hi Tack for gaskets like that when mating surfaces are clean and flawless. Used on one side it does a nice job of keeping a gasket in place.
bern
05-10-2019 17:29:07
Dry is fine as long as the mating surfaces are clean.
Fordfarmer
05-10-2019 17:49:12
 Re: 5000 rear split in reply to bern, 05-10-2019 17:29:07
The way the old gasket came off, that's what I was kinda thinking, but I figured it was best to ask. I appreciate all the experience and knowledge that's shared here.
SkipperII
05-10-2019 20:23:30
 Re: 5000 rear split in reply to Fordfarmer, 05-10-2019 17:49:12
Make sure you get the bolts real tight when you reassemble it. If you don't, they sections will actually twist, then tear the gasket. We got a lot of new ones that did it. Became standard procedure to tighten everyone that came through the door.
Fordfarmer
05-11-2019 07:18:13
 Re: 5000 rear split in reply to SkipperII, 05-10-2019 20:23:30
There are torque values in the manual... they will be followed.
Bern
05-11-2019 05:25:39
There's no way it can twist with the dowels in place - are you sure you are talking about Fords here? I've never seen a Ford tractor come loose at that joint and do what you describe. A person would have to intentionally take the dowels out in order for that to happen.
What new model Ford tractors did you feel it necessary to do that to?
Latest Ad: need 3 point arms (with the ball) especially need the [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
