8600 oil leak
KYCASE1
The o-rings on the (Lower Lift Link Torsion Bar System) shaft that the 3point arms hook to,are
leaking. This shaft goes through the lower part of the rear end housing. How big of a project is
it to replace these o-rings? Thanks for any help.
The RH side is easy, the LH side is a bear, at least the way it's supposed to be done. This is because the shaft needs to be pulled out to get to the LH seal, and there is internal linkage holding the shaft in place.
I've heard of people stretching a new o-ring over the arm on the LH side and getting a new one in there, but I've never tried this myself.
