Junkyard Jubilee
JDEM
I was at an auto junkyard looking for frame-parts for my 94 Chevy truck. I came across this NAA. I was told it had been sitting there for
7-8 years after it would not start one Spring. I agreed to buy it for $800 if I could get it running and the major stuff check out okay.
I have never come across a fuel system so plugged from such a relatively short period of time. I had to use drill bits to ream out the
passages in the carb and the sediment bowl. Filed the points, stuck a battery in it and it started right up. To my surprise, trans and
clutch works fine, PTO is fine, and engine runs great. So I now have it home. Came with a kind of awful loader with a manure bucket that I
will likely not use.
Question from a non-Ford guy. What the heck is the PTO shaft extension for? It is not an adapter and not an over-running clutch. Just an
extension.
Congratulations on your new kitten....er...tool -
The PTO extension appears to be an adapter to increase the PTO size from 1-1/8th inch to the modern standard 1-3/8th inch -
it does look remarkably good for setting around a salvage yard for that long - hard to believe it wasn't picked or vandalized - I hope it serves you well -
"Question from a non Ford guy?" You brought it home with a Ford. You are a Ford guy :) The OEM PTO on the NAA is the larger 1 5/8 shaft, so I don't know what that was for.
that naa left the factory with a small 1 1/8 pto stub.. short and low diameter. someone slipped a sleeve extension/adapter on it to make it about the same lenght as the new style pto shafts that are 1 3/8" diameter.
Soundguy, thanks for the PTO lesson. I knew the PTO on my NAA was larger than the one on my 2N. When I bought a rotary mower, new, modern, it fit right on it and I'm glad it did. Lesson learned.
In my experience, the vane hydraulic pump was a very weak link. If it fails to lift with hot oil, go for the piston pump.
I guess I should of worn my glasses when I looked at that PTO extension. I thought it was the same size as the stub it slid over. I knew about the adapters. Just looked the same to me at the time, but like I said. I was not wearing my $1 reading glasses.
For $800, I cannot complain. Runs great and picked up the loader today that came with it. Just an up and down loader with a trip-activated manure bucket, but I was not going to leave it behind.
This Jubilee came up for sale in my area today. Going by the price this seller wants I guess I did good at the junkyard.
