i have a ford 3000 it backfired thru the exhaust and died. i hit it with starting fluid and it would run on that and then take off. after a few rounds in the field this happened 3 more times. then would not hit on starting fluid. i went and replaced the points condenser wires and plugs. no help. i then took off my Holley carb and replaced it with a zenith carb. no help. plugs do not seem to be wet as i think they should be.
I have 90 plus compression on all 3 cylinders low but equal
i have spark when i lay the plugs on the intake and watch them while cranking.
I have gas to the carb and after cranking with the choke on gas runs out of the carb intake.
valves have no broken springs ect.
any help will be appreciated as i am in need of this to finish fertilizing.
