1970 ford 4000 su & blue streak points?
swattley
does anyone know the numbers for points, cond, cap and rotor by standerd ign. Blue streak points. these are the only points that hold up in my 88 wellcraft that i fish off the jersey coast. my tractor cap and rotor are burnt and i have not even got into look and the points contact thanks to that large loader frame and a bad leg. (FUN) I saw a 2n post about bluestreak in here.
i was knocking small trees down last night with the loader up in air and motor starting to run rough. i had plan on new ign parts just not got to it yet.
any thoughts on NGK plugs? i want to get the best so when it is up on the mountain in the catskills i not have any problems.
Points - FD 8081
Cond - FD 75
NGK Plugs 3112
Can't help w/the other parts you mention as I don't have that info available right now.
I have been having very good luck w/NGKs in all 5 Fords from a '43N to a 3000. The 3000 has always been hard to start, had to feather the throttle & choke at the same time & start 5-6 times before it would finally take off & run up to speed. Ditched the new Autolites & installed NGKs & problem solved!
the 70 ford 4000 su has a 201cid 3 cylinder engine, those points are not for the 3 cylinder, i think they for the 4 cylinder.
i have located all the Blue streak ignition points, cap, and rotor#s if anyone is interested in the numbers.
next i want to make sure this NGK 2635 spark plug is the correct heat range plug for this old engine. has anyone used ngk plugs in there 3 cylinder 201 engine and can confirm this number or suggest another number?
My apologies! You're right, the ones I gave you are for the 4 cylinder. For my 3000 I use (if I can read my writing!):
Plugs NGK B4ES #4129
Points FD-6769X (not sure about the X)
Condenser FD-71
Cap FA350
Rotor FD-126
