Just bought a 801 Powermaster 841 series and the rear lift arms would not work. Not knowing the last time the fluids were changed I drained the rear diff, the hyd., and the tranny. Filled all levels to the top
of the sight plugs until it ran out the installed the plugs.Bled the hyd. pump and the hydraulics worked great for about 15 minutes of run time then oil started running out of the gear shift boot.. A lot. I
removed the sight level plug for the tranny and it was way over full and the hydraulic level did not touch the stick. Is this a pretty good sign that the hyd. tube is bad? Has anyone changed one before? Just
wandering how hard it is to replace the tube if thats what my problem is. Thanks for your time and help
Scotty
Scotty
