Off Road SHO
Was told it was a 340B, it has the 3 cylinder diesel and these are the numbers under the hood
Tractor Number BD19838
Model Number CU5NW2
Engine 35789**2F16 ( I can't read the asterisk position)
Transmission 2D08B
Rear Axle 2D14B
Hydraulic Puump 2F11B
Hydraulic Lift 2F17A
Unit ***17B
Some of the above numbers are also stamped on the right side bell housing flat.
On the left side bell housing flat there are these numbers:
OU05
2D08
30770
I am slowly trying to put this tractor back together (got it as a basket case) and I would like to get new or reman fuel injectors so that is one less thing I have to worry about. The numbers on the fuel injectors (3 of them) are:
BKBL80S5437
DN5222305 EK
I cannot find an exact match on those injector numbers buy I also don't know which numbers are important. Thanks
Tom Too Many Tractors Dooley
Model Number CU5NW2
Transmission 2D08B
Rear Axle 2D14B
Unit ***17B
OU05
2D08
30770
BKBL80S5437
DN5222305 EK
