Company Logo Shop Now
Order Ford 4000 Parts Online
Ford 4000 motor 3 cylinder rpms crazy
mikewood869
05-07-2019 05:34:42
Just wondering how high does the rpms go on that motor? The stick shows that the motor will go past 26 rpms which maxs the gauge.
mikewood869
05-23-2019 06:05:31
 Re: Ford 4000 motor 3 cylinder rpms crazy in reply to mikewood869, 05-07-2019 05:34:42
Sorry. back in the late 1980's, a guy my grand father knew rewired the tractor, then in the summer of 2017, we bought a wiring harness and generator and rewired the tractor. We ended up pulling the pulley and that part that goes on for the tach cable from a generator from a parts gas 3000 )https://www.amazon.com/gp/product/B008XBBVLA/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
The old alternator for the tractor
Sean in PA
05-23-2019 04:50:37
I'm sorry, but I just re-read the sentence above and I am confused. If it had an alternator, then how could you use the generator from it?
mikewood869
05-22-2019 12:52:24
They seem like the same size pulley. I know the old tach wasn t working too.
Sean in PA
05-22-2019 11:57:32
Did the two generators have two different sized pulleys on them?
mikewood869
05-22-2019 10:58:23
We ended up using the generator from the 3000 gas motor (which had a alternator). The belt that is on the tractor right now is 2 inches smaller (the bracket that mounts near the valve cover doesn t even attach). The rpm gauge isn t as far off as before.
Destroked 450
05-22-2019 10:30:27
Is this the original generator or has it been converted to a alternator.
The alternator conversion kits I've gotten have caused the tach readings to be high by 3-400 rpm's
Sean in PA
05-22-2019 09:57:48
But it would ride lower in both pulleys (crank and generator pulley) so the rotational speed of the 2 pulleys relative to each other wouldn't change.
sotxbill
05-22-2019 06:20:25
A very narrow belt that rides deep into the pulley would show higher revolutions than the correct belt that rode further out and had to travel further per revolution.
Sean in PA
05-22-2019 05:49:43
The belt size shouldn't matter unless it's so narrow that it slips, in which case the results would be similar to a loose belt, which would slip as well and wouldn't spin the pulley on the generator as fast as it would if it wasn't slipping so the tach should read slower than the engine is actually turning, not faster.
The generator itself wouldn't cause the tach to be off. The size of the pulley on the front of the generator or an incorrect tach drive mechanism on the back of the generator might, but not the generator itself.
mikewood869
05-21-2019 20:47:37
So far this was probably caused by a loose belt, smaller belt or the generator.
Check Break
05-07-2019 17:20:52
Might be a good idea to compare your tachometer reading with one from a digital tach. Like all things digital, they're almost free these days.
One option is ... https://www.harborfreight.com/digital-photo-sensor-tachometer-66632.html
sotxbill
05-07-2019 16:55:55
I'm not sure what your saying, but....
If someone messed with the adjustments, it can run way faster... But that would greatly shorten the life of the engine.
Destroked 450
05-07-2019 16:40:24
Generators, tachs are all the same gas or diesel.
mikewood869
05-07-2019 10:35:59
I might just swap the gas one that we bought last year. Right now it has the one from the diesel motor.
Destroked 450
05-07-2019 09:11:43
4000 3 cyl's max rpm is 2450-2500, it's common for a tach to be off a hundred rpm or so.
If it has a alternator conversion it'll be way off, by as much as 500 rpm fast, a bigger pulley will help but won't completely fix it.
I had the gen pulley bored to fit a Delco alt, tach is still off about 300 rpm.
Used my digital tack to find 540 pto speed, tractor with swapped pulley shows 2100 rpm, tractor with Delco pulley shows 2300.
sunbeam
05-07-2019 06:56:05
What kind of tach drive? If it was a generator driven tach and changed to an alternator it might be pulley size.
Today's Featured Article - The Niagra View Mobile - Powered by a 1959 Ford Tractor - by Mark Massey. In 1959 the Niagara Frontier Transit Inc. of Buffalo, New York designed and built six Viewmobiles for the Niagara Frontier Sightseeing Inc. for use as a sightseeing ride at the Niagara Falls State Park, Niagara Falls, New York, powered by a 1959 Ford 611 Tractor. ... [Read Article]
Latest Ad: Hiniker 1300 rear window frame looking for one closer to Iowa the better [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
