NineSixtyOne
JMOR, successfully pulled the valve seat. Again, Thank you!
I have turned my attention to O-rings in the Hyd. cylinder assy.
Question: Do you, or anyone else, have any words of wisdom for pulling the unloading valve? If I understand correctly it appears that the threads on the unloading valve plug (39) can be used to pull and gain to access to the O-ring (44) around the unloading valve (45).
I may have it backwards. But I think once I have access to this O-ring and replace it the rest should be fairly easy. Maybe.
Thanks again.
Thanks again.
