Company Logo Shop Now
converting a 3cyl gas to lpgas
billyar
05-06-2019 16:37:59
Will a '74 3cyl run good converted to lpgas
Sean in PA
05-12-2019 22:00:20
 Re: converting a 3cyl gas to lpgas in reply to billyar, 05-06-2019 16:37:59
The parts site shows the same crankshaft, pistons and head for gasoline and L.P.G engines. What would cause a higher compression ratio on the LP engines vs. the gassers?
Texasmark1
05-12-2019 14:08:27
There are separate listings in the I&T manual since the regulator and all has to be addressed. On functionality, I had ONE LP tractor in 40 years of trying to learn how to farm,, my first JD, a 4020 with about 5k hrs...................................I tried to find a carburetor and manifold hookup to fit it...........................
Dr ken
05-06-2019 23:30:49
Quoting Removed, click Modern View to see. What kind of a forklift?
billyar
05-07-2019 07:51:47
 Re: converting a 3cyl gas to lpgas in reply to Dr ken, 05-06-2019 23:30:49
warner/swayse looks like a 3550 tractor under it
billyar
05-06-2019 20:59:10
It's in a forklift
Dean
05-06-2019 19:12:35
Not really, even if you can source the parts.
NG and LP engines usually have a higher CR.
Though you can make it run, it will be down on HP.
Dean
Shaun Wallace
05-06-2019 18:29:55
Ford offered a 3 cyl 4000 setup as factory LP. I have seen 2 in about 50 years.
Alvin 41
05-06-2019 18:15:00
Can be pretty complicated job to fit tank ,electric fuel shutoff, regulator with water coolant connections, carburetor ,and any starting controls. Fuel is cheap and easy to refuel off any propane storage tank. Used a 770 Oliver LP for 30 years mixing dairy cow rations with less fumes inside barns.
David G
05-06-2019 17:25:20
I would see no reason why not.
Latest Ad: John Deere A 1945 styled [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
