shaft for vane pump on 735 Loader
I started looking for replacement parts for the shaft on the vane pump for the 735 loader. On this website they show 290481 shaft and 7707570 coupling. are these the replacement type parts for the old shaft type with u-joints? it keeps coming up in my search. This is for the engine mounted vane pump on the front of the 1969 3500 tractor
Thanks', I have that but the price is out of my budget. I have the style on the bottom and was wondering if I could use the other style that is on there
If I remember correctly, there are several inches in length between the styles, I?m sure with some care and a good welder one of the shafts could be
shortened and rewelded
I called a driveline shop I use and since the shaft don't move and is centered with the crank he said he could make one with the slip yoke on the pump for engine play so it could move in and out and not be tight is what I am trying to say.
