871 SOS Terminal Block Location
ralphco
New User
Finally rewiring my 871 SOS tractor. I found the terminal block split in two and just dangling under the dash. I don't find any studs or other evidence where it was originally mounted. I'd appreciate any info (or pictures) letting me know where it should go. (Probably doesn't really matter but I'd like to get it right if I can.) Thanks all!!
just a little above and to the right of the voltage regulator. Kinda hard to get a good picture up in under there. This is my '63 4000 gasoline tractor.
Thanks Larry! I'll look up in that area a little closer and see if I can see where it used to be mounted.
