641 spindle bearings
fran213
When replacing spindle bearing on a 641 which way should the bearing face, with the piece that turns facing up or down ?
I assume you mean the thrust bearing.
I always installed them so if any water entered the bearing it could run back out and not be trapped. So with the turning part at the bottom.
