3000 shutoff while running
Checked for fuel coming to the filter which was changed couple of days ago when I first got tractor.Fuel is arriving at filter but dont know which line to check to see if it is leaving. It is definately not getting fuel because it will crank on ether? Anybody got any ideas or suggestions, All will be appreciated! Tractor was running and cranking fine prior although havnt run it even 2 hours since getting it?
Remove the filter and check for an extra gasket up in the housing. It is easy to do and it will block the little slots around the edge that the fuel is supposed to come out through.
Sounds like it just needs bleeding. Open the bleed screw on the side of the pump to make sure you get a dribble of fuel there. Then move to the injectors and crack them open one by one whilst cranking.
Since it is new to you would be a good idea to replace the fuel filter(s) and bleed the lines. I and T manual available at TSC will show you how to do it and bleed the system. There is/is supposed to be a seal imbedded in the top cover of the filter(s) so in changing such ensure you finish with only one "new" rubber seal there.
There is also a screen in the tank which is attached to the drain cock that could be clogged if you test and do not get fuel to your filter(s).
(quoted from post at 05:30:10 05/03/19) Since it is new to you would be a good idea to replace the fuel filter(s) and bleed the lines. I and T manual available at TSC will show you how to do it and bleed the system. There is/is supposed to be a seal imbedded in the top cover of the filter(s) so in changing such ensure you finish with only one "new" rubber seal there.
Mark, it probably doesn't need a new filter as it is just two days old.
