harryrub
New User
I have a Ford 600 with Wagner loader front bucket and Sherman backhoe. Tractor does not seem to have the hydro reservoir on 600's without the attachments and no hydro filler cap under the seat. Only filler caps at transmission and rear differential. Is this a modification made when the bucket and hoe are added or is it a different model altogether? Any info would be great. I am new to the forum and this is my first post.
It could have been ordered as a 620 which would have no pto or 3pt. Your fill cap for the hydraulics would have been on the 3pt top cover. If 640 model the pto
and hydraulic could have been deleted when backhoe was added.Here is the location for your model number, just behind the starter above the two holes.
<a href="https://imgur.com/rEJMUFD">
rEJMUFDl.jpg" title="source: imgur.com"
</a>
I'm guessing it's a 620, those didn't have a three point hitch and
therefore would not require the hydraulic reservoir. Check the
model number. The model number and serial number are stamped on the flat spot to the rear of the starter on the bell housing.
is your seat mounted to a more or less blank plate. if yes, as the others mentioned.. it could have either been deleted when the
hoe was added, or was a *2 model when ordered.
