Good afternoon,
I was asked by a friend of mine to help start a Ford 4000 diesel. Not sure what year it is, looked for serial number but it is not legible. It did run last year but is dead now. Wiring is in very bad shape, missing some, brittle and corroded. I was able to jump the starter solenoid and it does turn over. But that is it! It is a 12 volt system. My question is there a simple re-wire to just get it running? Ignition switch is in operable, terminal block which I believe has 4 terminals on it is broken, switch for manifold heaters broken and so on. Any help would be appreciated
