1974 Ford 2000 steering control valve
mds1315
New User
I need a picture of the steering control valve assembly. It fell apart on me and I need the positions for the pins and springs/check valve/balls ect.
Any help is appreciated.
Note the extra fitting by the yellow pencil.
That goes on the Right side at the top.
Right is Always as you are sitting in the seat.
There are 8 plungers, 2 balls and 3 springs in that valve.
Note the green pencil.
In that port install one special plunger horns up, then 2 balls then the other special plunger horns down.
The other 3 holes get an ordinary plunger, then a spring then another ordinary plunger.
Ultradog MN,
Thank you very much! I'm going to put it together right now. Its been out of commission for weeks.. If anyone has a loader for a 74' Ford 2000 I'm interested as well!?
Regards
