help identify loader tractor
illbdipt
looked at a ford industrial loader today with a damaged 3 cylinder diesel engine .has a 6 speed transmission with high and low.has a 3 point hitch and pto. owner says its a 1973. has been repainted sometime in the past and has a 3400 decal on front/side of hood. numbers on foil tag under hood and on flat area on right side of bell housing match and are as follows.
B1022B
3L09B
C403808
left side of engine block says new Holland with their insignia and HG2 5F09 cast into block .also has a lucas injector pump made in the uk, and what looks like a 12 volt generator also made by lucas .tag on loader reads as follows 19528 and 591232.
also included is a 4500 donor tractor with a good engine - numbers cast into that block are as follows
DONN 6015 L
2B 2 13
will that engine fit ? and everything hook up properly? only thing I noticed was what I think is the hyd. pump on left rear of 3400 block for the 3 point hitch there is not one on the donor 4500 there is a cover bolted on where it should be.
any and all input will be appreciated not to familiar with these fords
Ended up swapping a ford 3000 gas motor with a 4500 diesel engine. We just need to make a new route for the air cleaner (thinking of going around the battery). The throttle rod for the 4500 worked and the kill cable worked. Just the hood, fuel tank (one from 4500), and exhaust manifold didn't work. Everything else worked. The tractor has more power.
The 4500 engine will fit just fine. It has little more horsepower. May have to pull gear out of 3400 engine and put on 4500 engine. make shure casting been knocked out so oil will drain back.While in there replace freeze plugs in back of block.
thanks guys that's good to know, more horsepower is not a bad thing . shaun good idea about the frost plugs.1- not sure what you mean by knocking the casting out and 2-you mean the gear to drive hyd. pump?
Not all engines have pump drive gear installed for hyd pump mounted on engine so they were not installed. There is a drain hole in camshaft but when gear is installed it is covered. There is a indentation in lower part of that cavity that has real thin casting in it. If not punched out will have oil leak around pump.
I't's not a 3400.
Model code B1022B
B = 2000 model
10 = All purpose ag
2 = Gasoline engine
2 = Trans pto
B = 6x2 manual trans
B1022B is for a 2000 standard all purpose with gas engine, trans pro and 6x2 trans.
Production date 3L09B
Tractor was built Nov 9 1973 on day shift
Serial number C403808 is for a US tractor built in 1973.
Transmission and right side hood panel are for a gas 2000, does it have the gas air filter hole in the left hood panel.
sounds like it's had a later model diesel engine swapped on.
Does it have a straight 3400 front axle or the swept back ag axle.
(quoted from post at 20:55:31 04/28/19)
thought it was cobbled together. will swing by there after work for another look at things and post my findings .
looked at 3400/2000 again it has air filter on left side of hood and is connected to diesel engine in tractor. has a straight front axle and power steering cylinders on both sides if that helps you determine anything. the 4500 backhoe/loader with the donor engine numbers are
0373866
D5012k
3D11B
engine-3A10A
trans-2M196C
D5012K
D = 4000 series
50 = Industrial
1 = diesel engine
2 = trans 540 pto
K = 6x4 manual reverser trans
Tractor is a 4500 diesel with trans pto and 6x4 trans
3D11B production date
Tractor was built April 11 1973 on day shift
Serial # C373866 is for a tractor built in 1973
Where are you located?
If you are going to part out the 4500 I could be interested in some of the parts.
(quoted from post at 13:39:06 04/29/19)
D5012K
D = 4000 series
50 = Industrial
1 = diesel engine
2 = trans 540 pto
Same
Rats!! I'm in Ky, that's a little farther then I'd want to travel.
I need the transmission or all of the pto gears out of it.
I have a 4500 with no pto and would like to convert it.
PTO would make it a better tractor for my farm use.
I backed out of the deal, to much work for me. the guy is asking 3500 for both tractors, probably negotiate . if you have a big trailer and if its worth it to you let me know, I will let him know.
