I bought my first tractor over the weekend. Its a 7200 with dual power. I am having some difficulty with the 3pt. When I test drove it, it had a disc mower hooked up to it and lifted it fine so I didnt consider looking at it any closer. Now I have it home and have the following behavior in the 3 modes (Draft/Position/Load Monitor). All of this is with small 3 point plow attached.
Draft Mode - Lifts all the way up, goes down less than a foot.
Position Mode - Lifts most of the way up (not as high as draft mode), and lowers a bit further than Draft Mode
Load Monitor Mode - Lowers the furthest of all modes, but not deep enough to properly set the plow in the ground. Raises only a few inches from its low point.
I understand I need to use Position mode when wanting to control the 3pt. strictly with the lever. Is there any adjustment to allow the arms to drop lower and raise higher when in this mode?
Thanks.
Thanks.
