WorkingDad
91 250c, bought at auction last year. Was running great, but recently started slowly stalling after it warms up. I ve replaced the filters and tank valve. I ve also put clear lines in to see if there s air getting in the lines somewhere, nada.
When putting in the clear lines I saw something weird. There are two inlets on the filter, to outlets. One inlet is connected to the tank, normal. The other inlet is connected to the back of the injection pump. One outlet is connected to the side of the injection pump.
Shouldn t the back of the pump be connected to the other outlet?
Hard to see the line in these photos. The one in question is on the back side of the black hose going into the filter on the left side. Note the capped outlet as well.
